I setup Keycloak OpenID Connect. After some time, an error occurred in Rocket.Chat:
rocket_chat-rocketchat-1 | {"level":50,"time":"2023-06-13T13:18:19.275Z","pid":1,"hostname":"2067c7f848be","name":"System","msg":"Exception while invoking method login","err":{"type":"Error","message":"","stack":"Error: Failed to complete OAuth handshake with keycloak at https://id.mydomain.com/auth/realms/mydomain/protocol/openid-connect/token. network timeout at: https://id.mydomain.com/auth/realms/mydomain/protocol/openid-connect/token\n at CustomOAuth.getAccessToken (app/custom-oauth/server/custom_oauth_server.js:135:18)\n at Object.handleOauthRequest (app/custom-oauth/server/custom_oauth_server.js:193:26)\n at packages/oauth2/oauth2_server.js:10:39\n at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40\n => awaited here:\n at Function.Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:56:12)\n at packages/oauth/oauth_server.js:171:5\n at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40\n => awaited here:\n at Function.Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:56:12)\n at packages/accounts-base/accounts_server.js:1524:11\n at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40\n => awaited here:\n at Function.Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:56:12)\n at packages/accounts-base/accounts_server.js:653:7\n at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40\n => awaited here:\n at Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:60:12)\n at Server.apply (packages/ddp-server/livedata_server.js:1769:22)\n at Server.call (packages/ddp-server/livedata_server.js:1738:17)\n at Object.post (app/api/server/v1/misc.ts:612:27)\n at app/api/server/api.js:463:96\n at Meteor.EnvironmentVariable.EVp.withValue (packages/meteor.js:1329:12)\n at Object._internalRouteActionHandler [as action] (app/api/server/api.js:463:39)\n at Route._callEndpoint (packages/rocketchat_restivus/lib/route.coffee:150:32)\n at packages/rocketchat_restivus/lib/route.coffee:59:33\n at packages/simple_json-routes.js:100:9"},"msg":""}
Error in Keycloak:
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.security.elytron-web.undertow-server@1.10.0.Final//org.wildfly.elytron.web.undertow.server.ElytronRunAsHandler.lambda$handleRequest$1(ElytronRunAsHandler.java:68)
at org.wildfly.security.elytron-base@1.17.1.Final//org.wildfly.security.auth.server.FlexibleIdentityAssociation.runAsFunctionEx(FlexibleIdentityAssociation.java:103)
at org.wildfly.security.elytron-base@1.17.1.Final//org.wildfly.security.auth.server.Scoped.runAsFunctionEx(Scoped.java:161)
at org.wildfly.security.elytron-base@1.17.1.Final//org.wildfly.security.auth.server.Scoped.runAs(Scoped.java:73)
at org.wildfly.security.elytron-web.undertow-server@1.10.0.Final//org.wildfly.elytron.web.undertow.server.ElytronRunAsHandler.handleRequest(ElytronRunAsHandler.java:67)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.2.12.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.core@2.2.12.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.2.12.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.security.elytron-web.undertow-server-servlet@1.10.0.Final//org.wildfly.elytron.web.undertow.server.servlet.CleanUpHandler.handleRequest(CleanUpHandler.java:38)
at org.wildfly.extension.undertow@25.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@25.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:280)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:79)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:134)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:131)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@25.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1544)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:260)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:79)
at io.undertow.servlet@2.2.12.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:100)
at io.undertow.core@2.2.12.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:387)
at io.undertow.core@2.2.12.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:852)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1990)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
at org.jboss.xnio@3.8.4.Final//org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280)
at java.base/java.lang.Thread.run(Thread.java:829)
- Version of Keycloak: 6.1.4
- Version of Rocket.Chat Server: 6.1.4
- Operating System: Ubuntu 20.04
- Deployment Method:docker compose
- MongoDB Version: 4.4
- Proxy: nginx
