I was trying to setup on local and this is the error i am facing . I am new to this repo . Can someone guide me
OS : windows
RAM : 12gb
Node version : v20.18.0
Yarn : 4.5.3
Pay particular attention to ALL the requirements.
Read this and all the links and ALL the docs - the windows docs are not quite right - see the linux setup.
I have reffered the docs but idk whats the issue . Should i use Linux (sorry if i am being too naive)
That means you need to read a lot more. It is how we learned…
It will work on Windows but you need WSL - Windows Services for Linux.
So Linux on Windows.
Yes, it is much easier on a native linux install…
There are some small eerors in the Windows setuo docs.
Refer to the Linux version for more details.
I have WSL installed (specifically WSL 2)
Update: Thank you sooooo much was able to install all the dependencies and setup everything
My device has 12gb ram . But I am getting this error any work around or my device is incapable of handling the dev environment?
I used yarn dsv to run the dev environment
If you have done it correctly with 12Gb & WSL2 it will work.
Suggest you have a clear out, remove the repo etc and do a fresh install.
