So I’m using Ubuntu 16 and I’ve installed rocket.chat with snap. I’ve setup systemd and SSL with Let’s Encrypt. Following is my Nginx config file and I keep getting 502 Bad Gateway when I go to app.andrew.at.tw/chat. Who can help me out?
# Upstreams
upstream backend {
server 127.0.0.1:3000;
#HTTPS Server
server {
root /var/www/app;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name app.andrew.at.tw;
location ~/chat(.*)$ {
proxy_pass http://backend/$1;
proxy_http_version 1.1;
proxy_redirect off;
listen [::]:443 ssl; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/app.andrew.at.tw/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/app.andrew.at.tw/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
