"Error: a route URL prefix must begin with a slash"
Installing rocket-chat for the first time and I get this error. My .env file seems to have the correct format.
  • Version of Rocket.Chat Server: 6
  • Operating System: Ubuntu 20
  • Deployment Method: docker-compose
  • NodeJS Version:
  • MongoDB Version: bitnami/mongodb:5.0
  • Proxy: caddy
    docker compose:
volumes:
services:
  rocketchat:
    image: registry.rocket.chat/rocketchat/rocket.chat:${RELEASE:-latest}
    restart: always
    labels:
      traefik.enable: "true"
      traefik.http.routers.rocketchat.rule: Host(`${DOMAIN:-}`)
      traefik.http.routers.rocketchat.tls: "true"
      traefik.http.routers.rocketchat.entrypoints: https
      traefik.http.routers.rocketchat.tls.certresolver: le
      MONGO_URL: "${MONGO_URL:-\
        mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
        ${MONGODB_DATABASE:-rocketchat}?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      MONGO_OPLOG_URL: "${MONGO_OPLOG_URL:\
        -mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
        local?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      ROOT_URL: ${ROOT_URL:-http://localhost:${HOST_PORT:-3000}}
      PORT: ${PORT:-3000}
      DEPLOY_METHOD: docker
      DEPLOY_PLATFORM: ${DEPLOY_PLATFORM:-}
      REG_TOKEN: ${REG_TOKEN:-}
    depends_on:
      - mongodb
    expose:
      - ${PORT:-3000}
    ports:
      - "${BIND_IP:-0.0.0.0}:${HOST_PORT:-3000}:${PORT:-3000}"
  mongodb:
    image: docker.io/bitnami/mongodb:${MONGODB_VERSION:-5.0}
    restart: always
    volumes:
      - mongodb_data:/bitnami/mongodb
      MONGODB_INITIAL_PRIMARY_HOST: ${MONGODB_INITIAL_PRIMARY_HOST:-mongodb}
      MONGODB_INITIAL_PRIMARY_PORT_NUMBER: ${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}
      MONGODB_ADVERTISED_HOSTNAME: ${MONGODB_ADVERTISED_HOSTNAME:-mongodb}
      ALLOW_EMPTY_PASSWORD: ${ALLOW_EMPTY_PASSWORD:-yes}
.env file:
### Rocket.Chat configuration
# Rocket.Chat version
# see:- https://github.com/RocketChat/Rocket.Chat/releases
RELEASE=6.0.0
# MongoDB endpoint (include ?replicaSet= parameter)
#MONGO_URL=
# MongoDB endpoint to the local database
#MONGO_OPLOG_URL=
# IP to bind the process to
BIND_IP=127.0.0.1
# URL used to access your Rocket.Chat instance
ROOT_URL=https://chat.naff.casa
# Port Rocket.Chat runs on (in-container)
PORT=3000
# Port on the host to bind to
#HOST_PORT=
### MongoDB configuration
# MongoDB version/image tag
#MONGODB_RELEASE=
# See:- https://hub.docker.com/r/bitnami/mongodb
### Traefik config (if enabled)
# Traefik version/image tag
#TRAEFIK_RELEASE=
# Domain for https (change ROOT_URL & BIND_IP accordingly)
DOMAIN=chat.naff.casa
# Email for certificate notifications
LETSENCRYPT_EMAIL=ryan.naff@gmail.com
### Any additional Information
<!-- logs, additional setup information, anything extra you did in the setup or variables not included in any guide you followed -->
Make sure both your docker AND your docker-compose binary are a recent version. I ran into the same issue earlier because my compose was version 1.x.x
