Error when installing from docker-compose
Hello! I try to install rocket.chat according to the docker-compose documentation, but when I run docker-compose up -d I get an error:
ERROR: The Compose file './docker-compose.yml' is invalid because:
services.rocketchat.ports contains unsupported option: 'host_ip'
my file is docker-compose.yml taken from the official repository:
version: "3.7"
volumes:
services:
  rocketchat:
    image: registry.rocket.chat/rocketchat/rocket.chat:${RELEASE:-latest}
    restart: on-failure
    labels:
      traefik.enable: 'true'
      traefik.routers.rocketchat.rule: Host(`${DOMAIN}`)
      traefik.http.routers.rocketchat.tls: 'true'
      traefik.http.routers.rocketchat.entrypoints: https
      traefik.http.routers.rocketchat.tls.certresolver: le
      MONGO_URL: "${MONGO_URL:-\
        mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
          ${MONGODB_DATABASE:-rocketchat}?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      MONGO_OPLOG_URL: "${MONGO_OPLOG_URL:\
        -mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
          local?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      ROOT_URL: ${ROOT_URL:-http://localhost:${HOST_PORT:-3000}}
      PORT: ${PORT:-3000}
    depends_on:
      - mongodb
    expose:
      - ${PORT:-3000}
    ports:
      - host_ip: ${BIND_IP:-0.0.0.0}
        target: ${PORT:-3000}
        published: ${HOST_PORT:-3000}
        protocol: tcp
        mode: host
  mongodb:
    image: docker.io/bitnami/mongodb:${MONGODB_VERSION:-4.4}
    restart: on-failure
    volumes:
      - mongodb_data:/bitnami/mongodb
      MONGODB_INITIAL_PRIMARY_HOST: ${MONGODB_INITIAL_PRIMARY_HOST:-mongodb}
      MONGODB_INITIAL_PRIMARY_PORT_NUMBER: ${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}
      MONGODB_ADVERTISED_HOSTNAME: ${MONGODB_ADVERTISED_HOSTNAME:-mongodb}
      ALLOW_EMPTY_PASSWORD: ${ALLOW_EMPTY_PASSWORD:-yes}
My .env file
### Rocket.Chat configuration
# Rocket.Chat version
# see:- https://github.com/RocketChat/Rocket.Chat/releases
RELEASE=4.8.1
# MongoDB endpoint (include ?replicaSet= parameter)
#MONGO_URL=
# MongoDB endpoint to the local database
#MONGO_OPLOG_URL=
# IP to bind the process to
BIND_IP=0.0.0.0
# URL used to access your Rocket.Chat instance
ROOT_URL=rocket.mydomain.com
# Port Rocket.Chat runs on (in-container)
#PORT=
# Port on the host to bind to
#HOST_PORT=
### MongoDB configuration
# MongoDB version/image tag
#MONGODB_RELEASE=
# See:- https://hub.docker.com/r/bitnami/mongodb
### Traefik config (if enabled)
# Traefik version/image tag
#TRAEFIK_RELEASE=
# Domain for https (change ROOT_URL & BIND_IP accordingly)
DOMAIN=mydomain.com
# Email for certificate notifications
#LETSENCRYPT_EMAIL=
When running the old docker-compose.yml file there was no such problem.
Please tell me what caused this problem and how to properly fix it?
Hi! Welcome to our Community!
I just faced this issue today, and learned that my docker version was too old.
After updating to latest version, it worked properly:
$ docker --version
Docker version 20.10.17, build 100c701
Thanks for the advice, but I already have the latest version of docker installed. But you gave me the idea to check the docker-compose version and that was really the problem, 1.29.2 was installed.
Did you succeed on this? Which version of docker-compose did you update to?
