I host a small RocketChat instance on my local environment as proof of concept. I have an existing application that authenticates users using the Okta.
I want to embed RocketChat into my application such that my users only need to login to my application and I can use the same session to login to rocket chat.
My use case for the embed involved allowing users to change room from my application using the embed iframe commands.
I have actually done all that and made no progress.
And in no place in my questions did I ask someone to write it all out for me. Just a pointer would be ok.
The user.CreateToken endpoint that would have helped has been deprecated so I am looking for any alternative or if someone has done this before.
Not to engage in an internet argument with you, but you spent more time and energy trying to correct how I asked questions than providing any help at all.
A better way would be for you to ask for more context so you can help seeing that you are a ‘Community Liason Adviser’ (whatever that means).
A solution for this is available since 2019 but not in the documentation. Maybe you should spend time fixing that don’t you think?
A better way would be if you provided context in the first place then I wouldn’t be wasting my personal time trying show you how to provide it, and have to dig and find out where your issue really is. You’d have saved me a lot of my valuable time.
You haven’t even told us some basics on your Rocket version. How do I know it isn’t 5 years old?
So I presume my advice to search helped then?
As normal go to the correct doc page and fill in the error report so docs can correct it.
