Hi i am currently trying to export the message data from each channel on my rocket chat server for an audit. This is issue is that its a fairly old RocketChat server that basically has never been updated. I have been able to dump the the database into a series of .bson files but I am not sure where to go from there to make it more readable. Basically I need some thing to convert these .bson files to atleast the text of each channel
- Version of Rocket.Chat Server: 0.74.0
- Operating System: Centos
- Deployment Method: Its running raw
- DB Replicaset Oplog: Disabled
- NodeJS Version: unsure if its running node
- MongoDB Version: db version v2.6.12
- Proxy: The network is VPNed off from the public
- Firewalls involved: /\
Files i’ve been able to extract:
instances.bson rocketchat_livechat_inquiry.metadata.json instances.metadata.json rocketchat_livechat_office_hour.bson meteor_accounts_loginServiceConfiguration.bson rocketchat_livechat_office_hour.metadata.json meteor_accounts_loginServiceConfiguration.metadata.json rocketchat_livechat_page_visited.bson meteor_oauth_pendingCredentials.bson rocketchat_livechat_page_visited.metadata.json meteor_oauth_pendingCredentials.metadata.json rocketchat_livechat_trigger.bson meteor_oauth_pendingRequestTokens.bson rocketchat_livechat_trigger.metadata.json meteor_oauth_pendingRequestTokens.metadata.json rocketchat_livechat_visitor.bson migrations.bson rocketchat_livechat_visitor.metadata.json migrations.metadata.json rocketchat_message.bson _raix_push_app_tokens.bson rocketchat_message.metadata.json _raix_push_app_tokens.metadata.json rocketchat_message_read_receipt.bson _raix_push_notifications.bson rocketchat_message_read_receipt.metadata.json _raix_push_notifications.metadata.json rocketchat_oauth_apps.bson rocketchat_apps.bson rocketchat_oauth_apps.metadata.json rocketchat_apps_logs.bson rocketchat_oembed_cache.bson rocketchat_apps_logs.metadata.json rocketchat_oembed_cache.metadata.json rocketchat_apps.metadata.json rocketchat_permissions.bson rocketchat_apps_persistence.bson rocketchat_permissions.metadata.json rocketchat_apps_persistence.metadata.json rocketchat_reports.bson rocketchat_avatars.bson rocketchat_reports.metadata.json rocketchat_avatars.chunks.bson rocketchat_roles.bson rocketchat_avatars.chunks.metadata.json rocketchat_roles.metadata.json rocketchat_avatars.files.bson rocketchat_room.bson rocketchat_avatars.files.metadata.json rocketchat_room.metadata.json rocketchat_avatars.metadata.json rocketchat_settings.bson rocketchat_credential_tokens.bson rocketchat_settings.metadata.json rocketchat_credential_tokens.metadata.json rocketchat_smarsh_history.bson rocketchat_cron_history.bson rocketchat_smarsh_history.metadata.json rocketchat_cron_history.metadata.json rocketchat_statistics.bson rocketchat_custom_emoji.bson rocketchat_statistics.metadata.json rocketchat_custom_emoji.metadata.json rocketchat_subscription.bson rocketchat_custom_sounds.bson rocketchat_subscription.metadata.json rocketchat_custom_sounds.metadata.json rocketchat__trash.bson rocketchat_export_operations.bson rocketchat__trash.metadata.json rocketchat_export_operations.metadata.json rocketchat_uploads.bson rocketchat_import.bson rocketchat_uploads.chunks.bson rocketchat_import.metadata.json rocketchat_uploads.chunks.metadata.json rocketchat_integration_history.bson rocketchat_uploads.files.bson rocketchat_integration_history.metadata.json rocketchat_uploads.files.metadata.json rocketchat_integrations.bson rocketchat_uploads.metadata.json rocketchat_integrations.metadata.json rocketchat_user_data_files.bson rocketchat_livechat_custom_field.bson rocketchat_user_data_files.metadata.json rocketchat_livechat_custom_field.metadata.json rocketchat_webdav_accounts.bson rocketchat_livechat_department_agents.bson rocketchat_webdav_accounts.metadata.json rocketchat_livechat_department_agents.metadata.json ufsTokens.bson rocketchat_livechat_department.bson ufsTokens.metadata.json rocketchat_livechat_department.metadata.json users.bson rocketchat_livechat_external_message.bson users.metadata.json rocketchat_livechat_external_message.metadata.json usersSessions.bson rocketchat_livechat_inquiry.bson usersSessions.metadata.json
