I have been trying to upgrade my RC instance 4.7.4 with every new release and it remains to fail with a segmentation fault and it seems the developers do not care about this. I have launched numerous issues on Github and they are to this day open with no resolution in sight.
My latest report has been marked as closed, why I do not know. So I am hoping the community can assist with this, please?
I am going to repost my latest report here:
So after upgrading today to the latest release 5.0.5 from 4.7.4, I am presented with a common error most experience:
Aug 23 16:43:26 core rocketchat: /opt/Rocket.Chat/programs/server/node_modules/fibers/future.js:313
Aug 23 16:43:26 core rocketchat: throw(ex);
Aug 23 16:43:26 core rocketchat: ^
Aug 23 16:43:26 core rocketchat: MongoServerSelectionError: Server selection timed out after 30000 ms
Aug 23 16:43:26 core rocketchat: at Timeout._onTimeout (/opt/Rocket.Chat/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb/lib/sdam/topology.js:312:38)
To solve this, I added the &directConnection=true
to my MONGO_URL
and MONGO_OPLOG_URL
strings. Then, I get a new error:
[root@core opt]# node /opt/Rocket.Chat/main.js
/opt/Rocket.Chat/programs/server/node_modules/fibers/fibers.js:92
return fn.apply(this, arguments);
Error: Must pass options.rootUrl or set ROOT_URL in the server environment
at Object.Meteor.absoluteUrl (packages/meteor.js:1412:11)
And I fixed this by running
export ROOT_URL=https://rockethcat.example.com:3000/
export MONGO_URL=mongodb://localhost:27017/rocketchat
export PORT=3000
And now, I am at my Seg Fault with no solutions:
[root@core opt]# systemctl status rocketchat -l
● rocketchat.service - Example RocketChat Sever
Loaded: loaded (/usr/lib/systemd/system/rocketchat.service; enabled; vendor preset: disabled)
Active: failed (Result: signal) since Tue 2022-08-30 15:25:10 CAT; 2s ago
Process: 48513 ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js (code=killed, signal=SEGV)
Main PID: 48513 (code=killed, signal=SEGV)
Aug 30 15:25:04 hostname systemd[1]: Started Example RocketChat Sever.
Aug 30 15:25:10 hostname systemd[1]: rocketchat.service: main process exited, code=killed, status=11/SEGV
Aug 30 15:25:10 hostname systemd[1]: Unit rocketchat.service entered failed state.
Aug 30 15:25:10 hostname systemd[1]: rocketchat.service failed.
Segmentation fault
[root@core opt]#
What to do? Its been months
