Can't upgrade from v6.13.0 to v7.0.0
I switched to the next channel via
sudo snap switch rocketchat-server --channel=7.x/stable
and tried to refresh
sudo snap refresh rocketchat-server
The process got stuck with the following messages:
  • Run pre-refresh hook of “rocketchat-server” snap if present (run hook “pre-refresh”:
:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:42:54.552Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:42:55.640Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:42:55.640Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:42:56.736Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:42:56.736Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:42:57.835Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:42:57.835Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:42:58.915Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:42:58.915Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:00.001Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:00.001Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:01.100Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:01.100Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:02.226Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:02.226Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:03.316Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:03.316Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:04.407Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:04.407Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:05.499Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:05.499Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 “)
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{”$date":“2025-04-02T08:43:06.580Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-02T08:43:06.580Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 ")
[ERROR] mongod server start wait timed out
[ERROR] pre refresh migration script /snap/rocketchat-server/1634/migrations/pre_refresh/feature_compatibity/00-adopt_version.sh
Any suggestions how to proceed?
  • Version of Rocket.Chat Server: 6.13.0 (community version)
  • Operating System: Ubuntu 22.04
  • Deployment Method: snap
  • NodeJS Version: How to find on snap?
  • MongoDB Version: How to find on snap?
  • Proxy: nginx/caddy
  • Firewalls involved: ufw
You are using file storage not GridFS?
Your hardware supports newer Mongo eg AVX extensions?
You don’t mention what you are running it on. Check Mongo 5 compatibility.
First of it all, thank you for your reply. The MongoDB version is as follows
“name”:“MongoDB Internal Client”,“version”:“5.0.15”
thank you for your suggestion. I did the snap debug mode, but I don’t see a different output. So I spare you the whole output:
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{“$date”:“2025-04-14T08:15:40.677Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-14T08:15:40.677Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 ")
and I’m using GridFS
Read the docs.
Get off it, fast.
There are two file migrator repos about. Use them.
Do that before anything else.
You should also run a test dump, install, restore on another box.
Also read this.
Trying your suggestion gave me this error code:
/snap/rocketchat-server/1634/helpers/mongo.sh: line 50: ((: {“t”:{“$date”:“2025-04-15T06:48:04.415Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 : syntax error: operand expected (error token is “{“t”:{”$date":“2025-04-15T06:48:04.415Z”},“s”:“I”, “c”:“NETWORK”, “id”:5693100, “ctx”:“js”,“msg”:“Asio socket.set_option failed with std::system_error”,“attr”:{“note”:“connect (sync) TCP fast open”,“option”:{“level”:6,“name”:30,“data”:“01 00 00 00”},“error”:{“what”:“set_option: Protocol not available”,“message”:“Protocol not available”,“category”:“asio.system”,“value”:92}}}
1 ")
The snap refresh failed and there was still a mongo instance listening on port 27017 which I had to kill to be able to restart the rocketchat-server.
Finally I made it work again.
But I had to remove rocketchat-server and install it again. Here is my workaround:
First backup your data:
sudo service snap.rocketchat-server.rocketchat-server stop (stop server instance)
sudo service snap.rocketchat-server.rocketchat-mongo status | grep Active (check if mongo instance is still running)
sudo snap run rocketchat-server.backupdb (backup the data)
mv /var/snap/rocketchat-server/common/backup/rocketchat_backup_[timestamp].tar.gz /home/[user]/
(important step, move the backup file to any other location, replace [placeholders] with your corresponding inputs)
when the backup was successful, you can remove the rocketchat-server snap:
sudo snap remove rocketchat-server --purge (the “–purge” parameter was very important for me, without it didn’t work)
when it was successful, you can follow the new installation of the rocketchat-server and restore of the database backup as described here:
I am now on the latest release. (keep in mind, that all users have to relogin again)
That’ll be a mongo upgradd issue.
Thanks for posting your solution.
I thought this was clear when seeing my error “log” posts at the beginning of the thread..
Not specifically, no. Potentially lots of different issues with mongo - quick search will reveal that.
Hence the questions.
You have got off gridfs of course?
See this. Upgrading the OS to a newer version solve the issue.
Indeed, I’m using “filesystem” now. Thx for recommendation
