Hello !
I’ve launched RC on my machine using docker compose. Here is the file for configuration :
volumes:
services:
rocketchat:
image: registry.rocket.chat/rocketchat/rocket.chat:${RELEASE:-latest}
restart: always
labels:
traefik.enable: "true"
traefik.http.routers.rocketchat.rule: Host(`${DOMAIN:-}`)
traefik.http.routers.rocketchat.tls: "true"
traefik.http.routers.rocketchat.entrypoints: https
traefik.http.routers.rocketchat.tls.certresolver: le
MONGO_URL: "${MONGO_URL:-\
mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
${MONGODB_DATABASE:-rocketchat}?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
MONGO_OPLOG_URL: "${MONGO_OPLOG_URL:\
-mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
local?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
ROOT_URL: https://mydomaine.com
PORT: ${PORT:-3000}
DEPLOY_METHOD: docker
DEPLOY_PLATFORM: ${DEPLOY_PLATFORM:-}
REG_TOKEN: ${REG_TOKEN:-}
depends_on:
- mongodb
expose:
- ${PORT:-3000}
ports:
- "${BIND_IP:-0.0.0.0}:${HOST_PORT:-3000}:${PORT:-3000}"
mongodb:
image: docker.io/bitnami/mongodb:${MONGODB_VERSION:-5.0}
restart: always
volumes:
- mongodb_data:/bitnami/mongodb
MONGODB_INITIAL_PRIMARY_HOST: ${MONGODB_INITIAL_PRIMARY_HOST:-mongodb}
MONGODB_INITIAL_PRIMARY_PORT_NUMBER: ${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}
MONGODB_ADVERTISED_HOSTNAME: ${MONGODB_ADVERTISED_HOSTNAME:-mongodb}
ALLOW_EMPTY_PASSWORD: ${ALLOW_EMPTY_PASSWORD:-yes}
The only thing I changed is “ROOT_URL” with mydomain.com . I actually have a valid certificate for my real domain. I can access RC via http://localhost:3000 and it’s working fine. In order to access RC via https, I’ve configured a nginx rp with this configuration :
upstream rocketchat
server 127.0.0.1:3000;
server
listen 80;
server_name mydomain.com;
return 301 https://$host$request_uri;
server
listen 443 ssl;
fastcgi_param HTTPS on;
client_max_body_size 200M;
include configs/networks/ssl.conf;
location /
proxy_pass http://rocketchat;
proxy_http_version 1.1;
proxy_redirect off;
I’ve also changed the file /etc/host/ in order to redirect all the requests from mydomain .com to 127.0.0.1.
When trying to access https:/ /mydomain.com, I have 502 Bad Gateway error. Do you have any idea where this comes from ?
Thank you
- Version of Rocket.Chat Server: 6.5.3
- Operating System: Ubuntu
- Deployment Method: docker compose
- Proxy: nginx
