Application GUI crashes (bind)
We used Rocketchat on snap but the GUI kept crashing. Each start of the application you had to force a reload and could login. After this didn’t work anymore I decided to install it on docker and import the database. The error is still there
  • .Version of Rocket.Chat Server: 7.13.2
  • Operating System: Ubuntu 24.04
  • Deployment Method: Docker
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
TypeError: Cannot read properties of undefined (reading ‘bind’)
at module (shared.ts:2:45)
at verifyErrors.js:34:1
at g (url_common.js:81:1)
at d.require (url_common.js:81:1)
at e.require (verifyErrors.js:34:1)
at d.i [as link] (verifyErrors.js:34:1)
at module (rsa.ts:1:110)
ig @ verifyErrors.js:34
a.componentDidCatch.n.callback @ verifyErrors.js:34
as @ verifyErrors.js:34
sO @ verifyErrors.js:34
sm @ verifyErrors.js:34
sf @ verifyErrors.js:34
uc @ verifyErrors.js:34
ul @ verifyErrors.js:34
s1 @ verifyErrors.js:34
v @ verifyErrors.js:34
C @ verifyErrors.js:34
Não entendi nada e não sei como resolver o problema Application Error The application GUI just crashed.
Always search thoroughly.
This comment came originally from tech support:
Do you have custom CSS, custom scripts or custom fields? Any of them can cause GUI to crash.
If you have, try:
  • copy
  • remove
  • restart server
Should work to pinpoint what is causing the crash.
