Uploads bson files are empty after mongodump
I have RocketChat server with FileSystem storage setting for uploaded files. Uploading/downloading uploaded files works fine. But when I export rocketchat data by mongodump -o command I got rocketchat_uploads.chunks.bson and rocketchat_uploads.files.bson are empty as a result. I guess these files must not be empty. Isn’t it due to some collections corruption? What should I do to fix it?
Mongodump -o execution performs without any errors or warnings.
  • Version of Rocket.Chat Server: 6.4.2
  • Operating System: CentOS 7
  • Deployment Method: docker
  • NodeJS Version: 14.21.3
  • MongoDB Version: 5.0.18
  • Proxy:
  • Firewalls involved: no
Dump files list after mongodump -o /tmp_storage/dump execution:
root@561a45b89ceb:/# ls /tmp_storage/dump/rocketchat/ -la
total 1931700
drwxr-xr-x. 2 root root 12288 Sep 30 14:21 .
drwxr-xr-x. 5 root root 51 Sep 30 14:21 ..
-rw-r–r–. 1 root root 0 Sep 30 14:21 _queue.bson
-rw-r–r–. 1 root root 575 Sep 30 14:21 _queue.metadata.json
-rw-r–r–. 1 root root 35196 Sep 30 14:21 _raix_push_app_tokens.bson
-rw-r–r–. 1 root root 426 Sep 30 14:21 _raix_push_app_tokens.metadata.json
-rw-r–r–. 1 root root 35283 Sep 30 14:21 assets.chunks.bson
-rw-r–r–. 1 root root 304 Sep 30 14:21 assets.chunks.metadata.json
-rw-r–r–. 1 root root 321 Sep 30 14:21 assets.files.bson
-rw-r–r–. 1 root root 262 Sep 30 14:21 assets.files.metadata.json
-rw-r–r–. 1 root root 428 Sep 30 14:21 instances.bson
-rw-r–r–. 1 root root 304 Sep 30 14:21 instances.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 meteor_accounts_loginServiceConfiguration.bson
-rw-r–r–. 1 root root 390 Sep 30 14:21 meteor_accounts_loginServiceConfiguration.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 meteor_oauth_pendingCredentials.bson
-rw-r–r–. 1 root root 469 Sep 30 14:21 meteor_oauth_pendingCredentials.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 meteor_oauth_pendingRequestTokens.bson
-rw-r–r–. 1 root root 372 Sep 30 14:21 meteor_oauth_pendingRequestTokens.metadata.json
-rw-r–r–. 1 root root 193 Sep 30 14:21 migrations.bson
-rw-r–r–. 1 root root 177 Sep 30 14:21 migrations.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 omnichannel_auto_close_on_hold_scheduler.bson
-rw-r–r–. 1 root root 421 Sep 30 14:21 omnichannel_auto_close_on_hold_scheduler.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 omnichannel_queue_inactivity_monitor.bson
-rw-r–r–. 1 root root 526 Sep 30 14:21 omnichannel_queue_inactivity_monitor.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 omnichannel_scheduler.bson
-rw-r–r–. 1 root root 402 Sep 30 14:21 omnichannel_scheduler.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 pbx_events.bson
-rw-r–r–. 1 root root 274 Sep 30 14:21 pbx_events.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat__trash.bson
-rw-r–r–. 1 root root 583 Sep 30 14:21 rocketchat__trash.metadata.json
-rw-r–r–. 1 root root 952585 Sep 30 14:21 rocketchat_analytics.bson
-rw-r–r–. 1 root root 479 Sep 30 14:21 rocketchat_analytics.metadata.json
-rw-r–r–. 1 root root 29413 Sep 30 14:21 rocketchat_apps.bson
-rw-r–r–. 1 root root 269 Sep 30 14:21 rocketchat_apps.metadata.json
-rw-r–r–. 1 root root 13764 Sep 30 14:21 rocketchat_apps_logs.bson
-rw-r–r–. 1 root root 397 Sep 30 14:21 rocketchat_apps_logs.metadata.json
-rw-r–r–. 1 root root 96097 Sep 30 14:21 rocketchat_apps_packages.chunks.bson
-rw-r–r–. 1 root root 198 Sep 30 14:21 rocketchat_apps_packages.chunks.metadata.json
-rw-r–r–. 1 root root 103 Sep 30 14:21 rocketchat_apps_packages.files.bson
-rw-r–r–. 1 root root 197 Sep 30 14:21 rocketchat_apps_packages.files.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_apps_persistence.bson
-rw-r–r–. 1 root root 407 Sep 30 14:21 rocketchat_apps_persistence.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_apps_scheduler.bson
-rw-r–r–. 1 root root 406 Sep 30 14:21 rocketchat_apps_scheduler.metadata.json
-rw-r–r–. 1 root root 1006530 Sep 30 14:21 rocketchat_avatars.bson
-rw-r–r–. 1 root root 32121 Sep 30 14:21 rocketchat_avatars.chunks.bson
-rw-r–r–. 1 root root 335 Sep 30 14:21 rocketchat_avatars.chunks.metadata.json
-rw-r–r–. 1 root root 904 Sep 30 14:21 rocketchat_avatars.files.bson
-rw-r–r–. 1 root root 338 Sep 30 14:21 rocketchat_avatars.files.metadata.json
-rw-r–r–. 1 root root 448 Sep 30 14:21 rocketchat_avatars.metadata.json
-rw-r–r–. 1 root root 7478 Sep 30 14:21 rocketchat_banner.bson
-rw-r–r–. 1 root root 547 Sep 30 14:21 rocketchat_banner.metadata.json
-rw-r–r–. 1 root root 922 Sep 30 14:21 rocketchat_banner_dismiss.bson
-rw-r–r–. 1 root root 312 Sep 30 14:21 rocketchat_banner_dismiss.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_calendar_event.bson
-rw-r–r–. 1 root root 505 Sep 30 14:21 rocketchat_calendar_event.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_canned_response.bson
-rw-r–r–. 1 root root 377 Sep 30 14:21 rocketchat_canned_response.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_credential_tokens.bson
-rw-r–r–. 1 root root 419 Sep 30 14:21 rocketchat_credential_tokens.metadata.json
-rw-r–r–. 1 root root 3212 Sep 30 14:21 rocketchat_cron.bson
-rw-r–r–. 1 root root 396 Sep 30 14:21 rocketchat_cron.metadata.json
-rw-r–r–. 1 root root 10517 Sep 30 14:21 rocketchat_cron_history.bson
-rw-r–r–. 1 root root 454 Sep 30 14:21 rocketchat_cron_history.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_custom_emoji.bson
-rw-r–r–. 1 root root 518 Sep 30 14:21 rocketchat_custom_emoji.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_custom_sounds.bson
-rw-r–r–. 1 root root 353 Sep 30 14:21 rocketchat_custom_sounds.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_custom_user_status.bson
-rw-r–r–. 1 root root 358 Sep 30 14:21 rocketchat_custom_user_status.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_email_inbox.bson
-rw-r–r–. 1 root root 367 Sep 30 14:21 rocketchat_email_inbox.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_email_message_history.bson
-rw-r–r–. 1 root root 415 Sep 30 14:21 rocketchat_email_message_history.metadata.json
-rw-r–r–. 1 root root 973754 Sep 30 14:21 rocketchat_export_operations.bson
-rw-r–r–. 1 root root 440 Sep 30 14:21 rocketchat_export_operations.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_federation_dns_cache.bson
-rw-r–r–. 1 root root 285 Sep 30 14:21 rocketchat_federation_dns_cache.metadata.json
-rw-r–r–. 1 root root 2392 Sep 30 14:21 rocketchat_federation_keys.bson
-rw-r–r–. 1 root root 280 Sep 30 14:21 rocketchat_federation_keys.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_federation_peers.bson
-rw-r–r–. 1 root root 281 Sep 30 14:21 rocketchat_federation_peers.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_federation_room_events.bson
-rw-r–r–. 1 root root 570 Sep 30 14:21 rocketchat_federation_room_events.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_federation_servers.bson
-rw-r–r–. 1 root root 362 Sep 30 14:21 rocketchat_federation_servers.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_import.bson
-rw-r–r–. 1 root root 421 Sep 30 14:21 rocketchat_import.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_import_data.bson
-rw-r–r–. 1 root root 359 Sep 30 14:21 rocketchat_import_data.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_integration_history.bson
-rw-r–r–. 1 root root 504 Sep 30 14:21 rocketchat_integration_history.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_integrations.bson
-rw-r–r–. 1 root root 352 Sep 30 14:21 rocketchat_integrations.metadata.json
-rw-r–r–. 1 root root 7232 Sep 30 14:21 rocketchat_invites.bson
-rw-r–r–. 1 root root 272 Sep 30 14:21 rocketchat_invites.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_agent_activity.bson
-rw-r–r–. 1 root root 572 Sep 30 14:21 rocketchat_livechat_agent_activity.metadata.json
-rw-r–r–. 1 root root 2260 Sep 30 14:21 rocketchat_livechat_business_hours.bson
-rw-r–r–. 1 root root 377 Sep 30 14:21 rocketchat_livechat_business_hours.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_custom_field.bson
-rw-r–r–. 1 root root 363 Sep 30 14:21 rocketchat_livechat_custom_field.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_department.bson
-rw-r–r–. 1 root root 974 Sep 30 14:21 rocketchat_livechat_department.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_department_agents.bson
-rw-r–r–. 1 root root 647 Sep 30 14:21 rocketchat_livechat_department_agents.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_external_message.bson
-rw-r–r–. 1 root root 363 Sep 30 14:21 rocketchat_livechat_external_message.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_inquiry.bson
-rw-r–r–. 1 root root 1841 Sep 30 14:21 rocketchat_livechat_inquiry.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_page_visited.bson
-rw-r–r–. 1 root root 571 Sep 30 14:21 rocketchat_livechat_page_visited.metadata.json
-rw-r–r–. 1 root root 386 Sep 30 14:21 rocketchat_livechat_priority.bson
-rw-r–r–. 1 root root 367 Sep 30 14:21 rocketchat_livechat_priority.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_tag.bson
-rw-r–r–. 1 root root 366 Sep 30 14:21 rocketchat_livechat_tag.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_trigger.bson
-rw-r–r–. 1 root root 362 Sep 30 14:21 rocketchat_livechat_trigger.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_livechat_unit_monitors.bson
-rw-r–r–. 1 root root 451 Sep 30 14:21 rocketchat_livechat_unit_monitors.metadata.json
-rw-r–r–. 1 root root 10889 Sep 30 14:21 rocketchat_livechat_visitor.bson
-rw-r–r–. 1 root root 996 Sep 30 14:21 rocketchat_livechat_visitor.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_matrix_bridged_rooms.bson
-rw-r–r–. 1 root root 588 Sep 30 14:21 rocketchat_matrix_bridged_rooms.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_matrix_bridged_users.bson
-rw-r–r–. 1 root root 588 Sep 30 14:21 rocketchat_matrix_bridged_users.metadata.json
-rw-r–r–. 1 root root 1286361377 Sep 30 14:21 rocketchat_message.bson
-rw-r–r–. 1 root root 3009 Sep 30 14:21 rocketchat_message.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_message_read_receipt.bson
-rw-r–r–. 1 root root 543 Sep 30 14:21 rocketchat_message_read_receipt.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_message_reads.bson
-rw-r–r–. 1 root root 388 Sep 30 14:21 rocketchat_message_reads.metadata.json
-rw-r–r–. 1 root root 3295 Sep 30 14:21 rocketchat_moderation_reports.bson
-rw-r–r–. 1 root root 906 Sep 30 14:21 rocketchat_moderation_reports.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_notification_queue.bson
-rw-r–r–. 1 root root 753 Sep 30 14:21 rocketchat_notification_queue.metadata.json
-rw-r–r–. 1 root root 211 Sep 30 14:21 rocketchat_nps.bson
-rw-r–r–. 1 root root 301 Sep 30 14:21 rocketchat_nps.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_nps_vote.bson
-rw-r–r–. 1 root root 473 Sep 30 14:21 rocketchat_nps_vote.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_oauth_access_tokens.bson
-rw-r–r–. 1 root root 659 Sep 30 14:21 rocketchat_oauth_access_tokens.metadata.json
-rw-r–r–. 1 root root 306 Sep 30 14:21 rocketchat_oauth_apps.bson
-rw-r–r–. 1 root root 484 Sep 30 14:21 rocketchat_oauth_apps.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_oauth_auth_codes.bson
-rw-r–r–. 1 root root 400 Sep 30 14:21 rocketchat_oauth_auth_codes.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_oauth_refresh_tokens.bson
-rw-r–r–. 1 root root 416 Sep 30 14:21 rocketchat_oauth_refresh_tokens.metadata.json
-rw-r–r–. 1 root root 211839684 Sep 30 14:21 rocketchat_oembed_cache.bson
-rw-r–r–. 1 root root 362 Sep 30 14:21 rocketchat_oembed_cache.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_omnichannel_service_level_agreements.bson
-rw-r–r–. 1 root root 416 Sep 30 14:21 rocketchat_omnichannel_service_level_agreements.metadata.json
-rw-r–r–. 1 root root 269649 Sep 30 14:21 rocketchat_permissions.bson
-rw-r–r–. 1 root root 396 Sep 30 14:21 rocketchat_permissions.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_raw_imports.bson
-rw-r–r–. 1 root root 276 Sep 30 14:21 rocketchat_raw_imports.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_read_receipts.bson
-rw-r–r–. 1 root root 528 Sep 30 14:21 rocketchat_read_receipts.metadata.json
-rw-r–r–. 1 root root 6012 Sep 30 14:21 rocketchat_reports.bson
-rw-r–r–. 1 root root 272 Sep 30 14:21 rocketchat_reports.metadata.json
-rw-r–r–. 1 root root 1908 Sep 30 14:21 rocketchat_roles.bson
-rw-r–r–. 1 root root 422 Sep 30 14:21 rocketchat_roles.metadata.json
-rw-r–r–. 1 root root 2300939 Sep 30 14:21 rocketchat_room.bson
-rw-r–r–. 1 root root 5121 Sep 30 14:21 rocketchat_room.metadata.json
-rw-r–r–. 1 root root 83199590 Sep 30 14:21 rocketchat_server_events.bson
-rw-r–r–. 1 root root 552 Sep 30 14:21 rocketchat_server_events.metadata.json
-rw-r–r–. 1 root root 7852899 Sep 30 14:21 rocketchat_sessions.bson
-rw-r–r–. 1 root root 2377 Sep 30 14:21 rocketchat_sessions.metadata.json
-rw-r–r–. 1 root root 542648 Sep 30 14:21 rocketchat_settings.bson
-rw-r–r–. 1 root root 461 Sep 30 14:21 rocketchat_settings.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_smarsh_history.bson
-rw-r–r–. 1 root root 279 Sep 30 14:21 rocketchat_smarsh_history.metadata.json
-rw-r–r–. 1 root root 288768227 Sep 30 14:21 rocketchat_statistics.bson
-rw-r–r–. 1 root root 362 Sep 30 14:21 rocketchat_statistics.metadata.json
-rw-r–r–. 1 root root 4423082 Sep 30 14:21 rocketchat_subscription.bson
-rw-r–r–. 1 root root 2662 Sep 30 14:21 rocketchat_subscription.metadata.json
-rw-r–r–. 1 root root 8619 Sep 30 14:21 rocketchat_team.bson
-rw-r–r–. 1 root root 271 Sep 30 14:21 rocketchat_team.metadata.json
-rw-r–r–. 1 root root 90703 Sep 30 14:21 rocketchat_team_member.bson
-rw-r–r–. 1 root root 398 Sep 30 14:21 rocketchat_team_member.metadata.json
-rw-r–r–. 1 root root 87004575 Sep 30 14:21 rocketchat_uploads.bson
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_uploads.chunks.bson
-rw-r–r–. 1 root root 335 Sep 30 14:21 rocketchat_uploads.chunks.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_uploads.files.bson
-rw-r–r–. 1 root root 338 Sep 30 14:21 rocketchat_uploads.files.metadata.json
-rw-r–r–. 1 root root 605 Sep 30 14:21 rocketchat_uploads.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_userDataFiles.chunks.bson
-rw-r–r–. 1 root root 332 Sep 30 14:21 rocketchat_userDataFiles.chunks.metadata.json
-rw-r–r–. 1 root root 24933 Sep 30 14:21 rocketchat_user_data_files.bson
-rw-r–r–. 1 root root 535 Sep 30 14:21 rocketchat_user_data_files.metadata.json
-rw-r–r–. 1 root root 21146 Sep 30 14:21 rocketchat_video_conference.bson
-rw-r–r–. 1 root root 422 Sep 30 14:21 rocketchat_video_conference.metadata.json
-rw-r–r–. 1 root root 0 Sep 30 14:21 rocketchat_webdav_accounts.bson
-rw-r–r–. 1 root root 440 Sep 30 14:21 rocketchat_webdav_accounts.metadata.json
-rw-r–r–. 1 root root 67465 Sep 30 14:21 ufsTokens.bson
-rw-r–r–. 1 root root 176 Sep 30 14:21 ufsTokens.metadata.json
-rw-r–r–. 1 root root 1507231 Sep 30 14:21 users.bson
-rw-r–r–. 1 root root 6898 Sep 30 14:21 users.metadata.json
-rw-r–r–. 1 root root 9200 Sep 30 14:21 usersSessions.bson
-rw-r–r–. 1 root root 497 Sep 30 14:21 usersSessions.metadata.json
Upgrade.
Your version is no longer supported.
At the very least do yourself a security favour and use the last 6.4.x
https://docs.rocket.chat/docs/version-durability
Use something like Studio 3T to view/browse the collections.
I think those two are related to files stored within GridFS so they should be empty if you are using file storage. Usually they have a bit in there as users test with GridFS and then switch and don’t bother clearing it out.
I think you will find file storage uses rocketchat_uploads to store links.
Nothing to fix as far as I can see. Apart from upgrading ASAP…
Ok, so which dump files store data about uploaded files if Filesystem storage type is used?
All there for you. You can also just use say jq & grep.
