Yasen
1
- Version of Rocket.Chat Server: 6.7.1 and 6.8.0
- Operating System: debian bullseye
- Deployment Method: snap
- Firewalls involved: none
caddy2 is started no mater if i set snap variable to disable or if I disable snap.rocketchat-server.rocketchat-server-caddy.service
reetp
2
We need to see what you are doing.
Can you show how you disable it please?
Commands, configs, logs etc.
Yasen
3
Well, obviously i have to stop it manually after setting caddy=disable. Me bad sorry.
And after machine reboot caddy is starting again
#lsof -Pni
caddy2 1009 root 3u IPv6 17738 0t0 TCP *:3000 (LISTEN)
caddy2 1009 root 7u IPv6 17741 0t0 TCP *:80 (LISTEN)
reetp
4
Please.
Also note my comments in your other thread.
You are likely wasting your time with snaps. They are too inflexible for your requirements.
Use docker for Rocket, Mongo, and your own proxy eg Nginx or Apache.
Yasen
5
Following this
# snap get rocketchat-server
Key Value
backup-on-refresh disable
caddy disable
ignore-errors false
mongo-oplog-url mongodb://localhost:27017/local
mongo-url mongodb://localhost:27017/parties
port 3000
siteurl http://localhost:3000
# systemctl status snap.rocketchat-server.rocketchat-caddy.service
● snap.rocketchat-server.rocketchat-caddy.service - Service for snap application rocketchat-server.rocketchat-caddy
Loaded: loaded (/etc/systemd/system/snap.rocketchat-server.rocketchat-caddy.service; disabled; vendor preset: enabled)
#reboot
#lsof -Pni
reetp
6
I don’t see a key for “caddy disable” in the docs.
I’ll ask the person who builds them.
