Our RocketChat server stopped working yesterday evening (as far as I can tell after an auto-update). It only presents a “Service Unavailable” error via the web interface.
I tried reverting it and also reinstalled and restored the last backup but could not revive it yet.
The overall message from the Web server is
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.4.25 (Debian) Server at chat.km3net.de Port 443
And the caddy service is not coming up:
root@pi1145:~# snap services
Service Startup Current Notes
rocketchat-server.rocketchat-caddy enabled inactive -
rocketchat-server.rocketchat-mongo enabled active -
rocketchat-server.rocketchat-server enabled active -
Snap status reports it’s running rocketchat-server 3.2.2:
root@pi1145:~# snap list
Name Version Rev Tracking Publisher Notes
core 16-2.44.3 9066 latest/stable canonical* core
rocketchat-server 3.2.2 1433 3.x/stable rocketchat* -
Caddy:
root@pi1145:~# service snap.rocketchat-server.rocketchat-caddy status
* snap.rocketchat-server.rocketchat-caddy.service - Service for snap application rocketchat-server.rocketchat-caddy
Loaded: loaded (/etc/systemd/system/snap.rocketchat-server.rocketchat-caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-05-13 01:54:16 CEST; 20h ago
Process: 4037 ExecStart=/usr/bin/snap run rocketchat-server.rocketchat-caddy (code=exited, status=1/FAILURE)
Main PID: 4037 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Server
root@pi1145:~# service snap.rocketchat-server.rocketchat-server status
* snap.rocketchat-server.rocketchat-server.service - Service for snap application rocketchat-server.rocketchat-server
Active: active (running) since Wed 2020-05-13 22:30:47 CEST; 2s ago
Main PID: 20632 (startRocketChat)
Tasks: 8 (limit: 4915)
CGroup: /system.slice/snap.rocketchat-server.rocketchat-server.service
|-20632 /bin/bash /snap/rocketchat-server/1433/bin/startRocketChat
`-20693 node /snap/rocketchat-server/1433/main.js
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: MongoDB shell version v3.6.14
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: connecting to: mongodb://127.0.0.1:27017/?gssapiServiceName=mongodb
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: 2020-05-13T22:30:47.559+0200 W NETWORK [thread1] Failed to connect to 127.0.0.1:27017, in(checking socket for error after poll), reason: Connection refused
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: 2020-05-13T22:30:47.560+0200 E QUERY [thread1] Error: couldn't connect to server 127.0.0.1:27017, connection attempt failed :
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: connect@src/mongo/shell/mongo.js:263:13
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: @(connect):1:6
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: exception: connect failed
May 13 22:30:47 pi1145 rocketchat-server.rocketchat-server[20632]: Checking if mongo featureCompatibilityVersion is correct, changing if not
MongoDB
* snap.rocketchat-server.rocketchat-mongo.service - Service for snap application rocketchat-server.rocketchat-mongo
Active: active (running) since Wed 2020-05-13 22:31:06 CEST; 835ms ago
Main PID: 21109 (sh)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/snap.rocketchat-server.rocketchat-mongo.service
|-21109 /bin/sh /snap/rocketchat-server/1433/bin/startmongo
`-21138 mongod --bind_ip 127.0.0.1 --pidfilepath /var/snap/rocketchat-server/common/mongod.pid --smallfiles --journal --dbpath=/var/snap/rocketchat-server/common --replSet rs0
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.201+0200 I CONTROL [initandlisten] modules: none
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I CONTROL [initandlisten] build environment:
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I CONTROL [initandlisten] distarch: x86_64
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I CONTROL [initandlisten] target_arch: x86_64
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I CONTROL [initandlisten] options: { net: { bindIp: "127.0.0.1" }, processManagement: { pidFilePath: "/var/snap/rocketchat-server/common/mongod.pid" }, replicat
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I - [initandlisten] Detected data files in /var/snap/rocketchat-server/common created by the 'wiredTiger' storage engine, so setting the active storage en
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.202+0200 I STORAGE [initandlisten]
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.203+0200 I STORAGE [initandlisten] ** WARNING: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.203+0200 I STORAGE [initandlisten] ** See http://dochub.mongodb.org/core/prodnotes-filesystem
May 13 22:31:06 pi1145 rocketchat-server.rocketchat-mongo[21109]: 2020-05-13T22:31:06.204+0200 I STORAGE [initandlisten] wiredtiger_open config: create,cache_size=2402M,session_max=20000,eviction=(threads_min=4,threads_max=4),config_base=false,statistics=
- Version of Rocket.Chat Server: 3.2.2
- Operating System: Linux pi1145 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
- Deployment Method: snap
- DB Replicaset Oplog:
- NodeJS Version:
- MongoDB Version: db version v3.6.14
- Proxy: apache
- Firewalls involved:
Here is the snap changes rocketchat-server output:
root@pi1145:~# snap changes --abs-time rocketchat-server
ID Status Spawn Ready Summary
50 Done 2020-05-12T23:44:23+02:00 2020-05-12T23:44:59+02:00 Refresh "rocketchat-server" snap from "2.x/stable" channel
51 Done 2020-05-13T01:23:21+02:00 2020-05-13T01:23:30+02:00 Revert "rocketchat-server" snap
52 Done 2020-05-13T01:29:53+02:00 2020-05-13T01:29:53+02:00 Change configuration of "rocketchat-server" snap
54 Done 2020-05-13T01:42:22+02:00 2020-05-13T01:46:18+02:00 Remove "rocketchat-server" snap
55 Done 2020-05-13T01:46:41+02:00 2020-05-13T01:46:56+02:00 Install "rocketchat-server" snap
