I’m sorry if this isn’t the correct place to post this question.
I’m currently struggling to implement a rocket.chat container behind a container that serves as an apache2 https reverse proxy.
I was looking at these parts of the documentation, but can’t quite get it to run with the information provided there.
https://github.com/RocketChat/docs/blob/master/installation/manual-installation/running-in-a-sub-folder/README.md
https://github.com/RocketChat/docs/blob/master/installation/manual-installation/configuring-ssl-reverse-proxy/README.md
Rocket.chat is supposed to be available in a sub folder of the main domain. The container is reachable from inside the docker network with dns name “rocketchat”, but says “Unknown Path” when I’m trying to access https://mydomain.de/rocketchat. My config has ROOT_URL=https://mydomain.de/rocketchat.
Although that same error is mentioned in the documentation, I can’t find a way to fix it.
The culprit is almost certainly the configuration on the apache2 container. From the previously mentioned documentation I concluded I had to add something like this to my apache2:
<Location /rocketchat>
Order allow,deny
Allow from all
RewriteRule /(.*) ws://rocketchat:3000/$1 [P,L]
RewriteRule /(.*) http://rocketchat:3000/$1 [P,L]
ProxyPassReverse http://rocketchat:3000/
</Location>
which is probably very wrong. The required modules, RewriteEngine are both activated though and the SSL proxy configuration is working fine. I already have a bunch of things running on it. I’d very much appreciate some advice as I’m a little stuck.
Thank you!
