We have a running rocket.chat instance with >100 users, but i am struggling to set-up automated signup. It should be closed community, so registrations should either be a) approved manually (works perfectly) OR b) done through a secret magic link and then automatically be approved (does not work).
We currently have a) but but also like to have option b) is this doable? I get an error message when I setup and try to access the secret URL Do both methods work in parallel or are they mutually exclusive? Are there good alternatives?
The Invites to a channel only work for existing accounts and not for creating new ones, right?
Thanks for pointing this out! I’ll ask the colleagues for an update!
However, I find the documentation a bit slim on this point.
Would it work as desired after an upgrade? Can users that use this secret link automatically be approved as desired or would this rather move the currently public registration form (that requires manual approval) to a secret URL (still requiring manual approval).
Ideally, I would like to have both: A public form requiring approval and a hidden form or secret key where the accounts automagically get approved and the admins only get a notification.
If you change the registration form to secret url, and set to Manually Approve New Users, it will always request approval.
Even when using the invite functionality.
However… you can leverage the invite feature and create a routine script, that will query for the users API, filtering by not active, that has a specific inviteToken, and activate them.
So if the user has the inviteToken, it means it came from that specific invite url you want to auto approve, and you can activate it also using another API endpoint.
As I have the same issue right now I’ve tested your suggestion. Unfortunately, it seem that the inivteToken field is only set to the user object after its first login. But the login only works with user being activated.
Do you see any other workarounds which could help in this case?
