QUICK RocketChat Java integration using RealTime API
Hello folks!
We are looking for a CONTRACTOR for a 1 week job for around 400-500€ :rocket:.
The job is quite STRAIGHTFORWARD! We want to integrate RocketChat from Java. To be more precise, we want to connect our Java application to RocketChat using WebSocket in order to create direct chats, public channels and private channels and send messages to those chats.
We also want to authenticate this RocketChat with an existing Auth0 server in order to use the existing tokens to log into RocketChat.
If you have experience working with Java and RocketChat, do not hesitate in contacting me at vceballos@moonshot.ceo!
I am looking forward working with you :raised_hands:t4:!
Hi there,
Hope you’re doing good.
PM sent, pls check.
Regards,
Luis
Hello @vceballos
I would like to work on your requirement.
PM sent with details, please check.
Regards
Diana
