Is there any1 already upgraded their workspace from 6.X to 7.X?
Badly need your process to make it work. Im encountering multiple failures and different errors depends on the node versions i installed as version prerequisites.
Thanks for providing some info.
Can you specify the recommended version of system (Ubuntu/Mongodb) for Rocketchat 7.5.1?
Made a clone for my existing server and updated my system to test updating with Rocketchat 7.5.1.
Ubuntu 22.04
Mongodb 6
Node 22.13.1
Below error i got from journal
rocketchat server 7.5.1 unable to start service, showing journalctl log “Apr 16 02:07:46 wa-rocketchat-clone rocketchat[4314]: strict mode: use allowUnionTypes to allow union type keyword at “#/properties/count” (strictTypes)
Apr 16 02:07:46 wa-rocketchat-clone rocketchat[4314]: strict mode: use allowUnionTypes to allow union type keyword at “#/properties/offset” (strictTypes)
Apr 16 02:07:47 wa-rocketchat-clone rocketchat[4314]: strict mode: missing type “object” for keyword “additionalProperties” at “#” (strictTypes)
Apr 16 02:07:47 wa-rocketchat-clone rocketchat[4314]: strict mode: missing type “object” for keyword “properties” at “#” (strictTypes)
Apr 16 02:07:47 wa-rocketchat-clone rocketchat[4314]: strict mode: missing type “object” for keyword “required” at “#/oneOf/0” (strictTypes)
Apr 16 02:07:47 wa-rocketchat-clone rocketchat[4314]: strict mode: missing type “object” for keyword “required” at “#/oneOf/1” (strictTypes)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: packages/core-runtime.js:189
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: throw error;
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: ^
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: Error: /opt/Rocket.Chat.releases/programs/server/npm/node_modules/isolated-vm/out/isolated_vm.node: undefined symbol: _ZN2v815ValueSerializer8Delegate19HasCustomHostObjectEPNS_7Isola>
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.load (node:internal/modules/cjs/loader:1275:32)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.Mp.load (/tools/static-assets/server/runtime.js:35:31)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Function.Module._load (node:internal/modules/cjs/loader:1096:12)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.require (node:internal/modules/cjs/loader:1298:19)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.mod.require (/opt/Rocket.Chat.releases/programs/server/node_modules/@meteorjs/reify/lib/runtime/index.js:30:33)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at require (node:internal/modules/helpers:182:18)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Object. (/opt/Rocket.Chat.releases/programs/server/npm/node_modules/isolated-vm/isolated-vm.js:1:18)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.Mp._compile (/tools/static-assets/server/runtime.js:78:21)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at npmRequire (/tools/static-assets/server/npm-require.js:133:10)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.useNode (packages/modules-runtime.js:750:18)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at module (/opt/Rocket.Chat.releases/programs/server/packages/modules.js:238927:8)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at fileEvaluate (packages/modules-runtime.js:335:7)
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: at Module.require (packages/modules-runtime.js:237:14) {
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: code: ‘ERR_DLOPEN_FAILED’
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: }
Apr 16 02:07:48 wa-rocketchat-clone rocketchat[4314]: Node.js v20.19.0
Apr 16 02:07:48 wa-rocketchat-clone systemd[1]: rocketchat@3000.service: Main process exited, code=exited, status=1/FAILURE”
We upgraded successfully to 7.0.x but there is an issue if you use the docker images from rocketchat/rocket.chat in future versions. We noted that a user named “rocketchat” will now run the server, which in turn requires us to change the owner of uploaded files so they remain accessible.
