Meteor Build command fails
Description:
I am trying to build Rocket.Chat 3.9.0 source in Dockerfile, but meteor build command fails
Here are the contents of my Dockerfile:
FROM ubuntu:18.04
RUN apt-get update
# Meteor requirements
RUN apt-get install g++ build-essential git curl -y
# Steps from Github workflow
RUN set +e METEOR_SYMLINK_TARGET=$(readlink ~/.meteor/meteor) METEOR_TOOL_DIRECTORY=$(dirname "$METEOR_SYMLINK_TARGET")
RUN set -e
# Install meteor
RUN curl https://install.meteor.com | sed s/--progress-bar/-sL/g | /bin/sh
# Install nodejs 12
RUN curl -sL https://deb.nodesource.com/setup_12.x | bash
RUN apt-get install nodejs -y
WORKDIR /usr/local/src/rocketchat
# Copy Rocket.Chat project to workdir, assuming that nodemodules is in dockerignore
COPY . .
RUN meteor npm install
RUN meteor build --allow-superuser --directory build
Steps to reproduce:
  1. Clone repo and checkout 3.9.0 tag: git clone https://github.com/RocketChat/Rocket.Chat.git && git checkout tags/3.9.0
  2. Create Dockerfile in project root
  3. Run docker build .
Expected behavior:
I expect meteor build --allow-superuser --directory build run smoothly, and generate output in “./build” directory.
Actual behavior:
meteor build --allow-superuser --directory build fails with strange error:
cp: cannot stat '/usr/local/src/rocketchat'$'\r''/node_modules/@rocket.chat/livechat/build/.': No such file or directory
internal/fs/utils.js:269
    throw err;
Error: ENOENT: no such file or directory, open 'index.html'
Server Setup Information:
  • Version of Rocket.Chat Server: 3.9.0
  • Operating System: Docker WSL2 on Windows
  • Deployment Method: docker
  • Number of Running Instances: 0
  • DB Replicaset Oplog: 0
  • NodeJS Version: 12.20.0
  • MongoDB Version: Not installed
Client Setup Information
  • Desktop App or Browser Version: No
  • Operating System: No
Additional context
I looked at Github workflow configuration, according to it, my Dockerfile looks fine.
I tried to move livechat devDependency to dependency, but it didn’t help.
I tried this approach on 3.9.0 and 3.8.2 tags, always same result.
I tried to manually install all of this in my WSL2 Ubuntu 18.04 environment, and faced the same problem.
Relevant logs:
Step 13/13 : RUN meteor build --allow-superuser --directory build
 ---> Running in 66f208a4a4df
Even with METEOR_ALLOW_SUPERUSER or --allow-superuser, permissions in your app
directory will be incorrect if you ever attempt to perform any Meteor tasks as
a normal user. If you need to fix your permissions, run the following command
from the root of your project:
  sudo chown -Rh <username> .meteor/local
jalik:ufs: updating npm dependencies -- mkdirp, spark-md5...
Livechat: updating npm dependencies -- uglify-js...
: not foundsrc/rocketchat/packages/rocketchat-livechat/plugin/build.sh: 5: /usr/local/src/rocketchat/packages/rocketchat-livechat/plugin/build.sh:
: not foundsrc/rocketchat/packages/rocketchat-livechat/plugin/build.sh: 7: /usr/local/src/rocketchat/packages/rocketchat-livechat/plugin/build.sh:
: not foundsrc/rocketchat/packages/rocketchat-livechat/plugin/build.sh: 10: /usr/local/src/rocketchat/packages/rocketchat-livechat/plugin/build.sh:
: not foundsrc/rocketchat/packages/rocketchat-livechat/plugin/build.sh: 13: /usr/local/src/rocketchat/packages/rocketchat-livechat/plugin/build.sh:
: not foundsrc/rocketchat/packages/rocketchat-livechat/plugin/build.sh: 17: /usr/local/src/rocketchat/packages/rocketchat-livechat/plugin/build.sh:
    throw err;
    at Object.openSync (fs.js:462:3)
    at Object.readFileSync (fs.js:364:35)
    at [eval]:1:35
    at Script.runInThisContext (vm.js:120:18)
    at Object.runInThisContext (vm.js:309:38)
    at Object.<anonymous> ([eval]-wrapper:10:26)
    at Module._compile (internal/modules/cjs/loader.js:1137:30)
    at evalScript (internal/process/execution.js:94:25)
    at internal/main/eval_string.js:23:3 {
  errno: -2,
  syscall: 'open',
  code: 'ENOENT',
  path: 'index.html'
/./private/livechatetchat/packages/rocketchat-livechat/plugin/build.sh: 22: cd: can't cd to /usr/local/src/rocketchat
cp: cannot stat '../../public/livechat/index.html': No such file or directory
/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/meteor-
promise/promise_server.js:218
      throw error;
Error: Couldn't parse stack frame: '  errno: -2,'
    at /root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/utils/tools/utils/pars
e-stack.ts:186:11
    at Array.some (<anonymous>)
    at parseStackFrames (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/util
s/tools/utils/parse-stack.ts:118:10)
    at Object.parse (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/utils/to
ols/utils/parse-stack.ts:64:21)
    at Object.exception (/tools/utils/buildmessage.js:534:29)
    at /tools/isobuild/bundler.js:2195:22
    at Function._.each._.forEach (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/d
ev_bundle/lib/node_modules/underscore/underscore.js:186:9)
    at JsImage.load (/tools/isobuild/bundler.js:2048:7)
    at /tools/isobuild/isopack.js:477:16
    at Object.enterJob (/tools/utils/buildmessage.js:388:12)
    at /tools/isobuild/isopack.js:467:20
ev_bundle/lib/node_modules/underscore/underscore.js:191:9)
    at Isopack.ensurePluginsInitialized (/tools/isobuild/isopack.js:455:7)
    at /tools/isobuild/compiler.js:381:16
    at Array.forEach (<anonymous>)
    at /tools/isobuild/compiler.js:380:26
    at /tools/isobuild/compiler.js:376:16
    at /tools/isobuild/compiler.js:186:28
    at Slot.withValue (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/l
ib/node_modules/@wry/context/lib/context.js:73:29)
    at Object.withCache (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/t
ools/fs/files.ts:1659:39)
    at /tools/isobuild/compiler.js:185:11
    at Object.compile (/tools/isobuild/compiler.js:180:5)
    at /tools/isobuild/isopack-cache.js:354:30
    at IsopackCache._loadLocalPackage (/tools/isobuild/isopack-cache.js:309:18)
    at /tools/isobuild/isopack-cache.js:243:16
    at Function.time (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/tool-en
v/tools/tool-env/profile.ts:284:12)
    at /tools/isobuild/isopack-cache.js:242:17
    at IsopackCache._ensurePackageLoaded (/tools/isobuild/isopack-cache.js:233:20)
    at /tools/isobuild/isopack-cache.js:75:14
    at /tools/packaging/package-map.js:57:7
    at exports.PackageMap.eachPackage (/tools/packaging/package-map.js:49:7)
    at IsopackCache.buildLocalPackages (/tools/isobuild/isopack-cache.js:74:24)
    at /tools/project-context.js:890:25
    at ProjectContext._buildLocalPackages (/tools/project-context.js:889:18)
    at /tools/project-context.js:300:9
    at ProjectContext._completeStagesThrough (/tools/project-context.js:290:18)
    at /tools/project-context.js:282:12
    at Function.run (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/tool-env
/tools/tool-env/profile.ts:289:14)
    at ProjectContext.prepareProjectForBuild (/tools/project-context.js:281:13)
    at /tools/cli/commands.js:1012:20
    at Object.capture (/tools/utils/buildmessage.js:283:5)
    at Object.main.captureAndExit (/tools/cli/main.js:275:29)
    at buildCommand (/tools/cli/commands.js:1009:8)
    at /tools/cli/commands.js:950:25
    at /tools/cli/commands.js:948:18
    at /root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/
meteor-promise/fiber_pool.js:43:40
 => awaited here:
    at Promise.await (/root/.meteor/packages/meteor-tool/.1.11.1.nmm7cg.gs54++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/li
b/node_modules/meteor-promise/promise_server.js:60:12)
    at /tools/cli/main.js:1529:7
The command '/bin/sh -c meteor build --allow-superuser --directory build' returned a non-zero code: 1
Any updates on it?
We’re experiencing the same.
Try with specification meteor version
Thanks @hazimal !
Yes, matching specific meteor version is very important. Also ensuring you have not used root privileges to run any part of the workflow.
We use the same workflow daily to develop and build Rocket.Chat.
