just a question:
Is there a way to remove a webdav integration again?
So I have added a webdav connection to a user account in order to be able to share files from my Nextcloud. But how can I remove this again? There is only a “+” (and no “-”)…
There seems to be no way to remove the webdav integration, once it is defined.
This is very unconvenient. Specifically, after making a mistake in my first webdav definition, I tried to at least overwrite the existing configuration by using the same name: This creates a second webdav entry with the same name.
Also disabling and reenabling the webdav integration on the system level does not help.
In the end I resorted to directly manipulating mongodb:
When running mongosh there is the database rocketchat with a collection called rocketchat_webdav_accounts that contains the entries.
For a docker-compose based setup this means:
docker-compose exec mongodb bash
mongosh
use rocketchat
db.rocketchat_webdav_accounts.find()
Then delete the webdav accounts you want to delete with
db.rocketchat_webdav_accounts.deleteMany({ _id: "some id you want to delete" })
I did not dive into the question whether I should update any other entries in addition. But as a userID is stored inside the “webdav_accounts” I assumed it is not necessary.
I had to restart my rocketchat client to have the entries disappear.
