Get UserID with Custom JS on client side
On a Rocket.Chat cloud hosted instance, is there a way to use Admin>Layout>Custom Scripts to retrieve the userID, email, user name, or custom field of a user during that (logged-in) user’s session?
The API can provide this information of course, but I don’t know how I’d authenticate (using custom JS on client side). As a work around, there might be some way to pull username off the DOM (would have to be on each page load), but I haven’t found it.
Background
  • My company has several “campuses” and I’ve successfully used “custom fields” + the API to assign a campus to each user profile.
  • I’ve also implemented Google Tag Manager, and I would like to track users by “campus” using Google Tag Manager. To do this, during each user’s session, I want to access that user’s custom field so I can push that value (eg. “New York City”) to Google Tag Manager’s data layer. (I have tried pushing test strings to the data layer using JS in “custom scripts”, so I know that part works)
  • If it’s not possible to access the custom field directly, if I can access the user’s UserID, email, or user name, I can use that information to call a database elsewhere and get the information.
  • Version of Rocket.Chat Server: 3.2
    Hosted on the Rocket.Chat cloud
Thought I’d bump this - does anyone have any suggestions?
Answering my own question here, in case it’s helpful to others.
The root of the problem was that I didn’t know how to log into the API from within a user session.
The userID and Token are stored in the Local Session under
meteor.UserID and meteor.loginToken. Easy to see in the Chrome Debugger:
To get it working, I created a custom HTML tag in Google Tag Manager. (I’d post another pic but “new users can only post one picture :roll_eyes:”)
Here’s the code (note we’re using some olde schoole JavaScript here (v5) because Google Tag Manager requires it):
<script>
var userCampus;
function getUserCampus(url) {
    var localUserId = localStorage.getItem('Meteor.userId');
    var localAuthToken = localStorage.getItem('Meteor.loginToken');
    var myHeaders = new Headers();
    myHeaders.append("X-User-Id", localUserId);
    myHeaders.append("X-Auth-Token", localAuthToken);
    var requestOptions = {
    method: 'GET',
    headers: myHeaders,
    redirect: 'follow'
    return fetch(url, requestOptions)
    .then(function (response) {
        return response.json();
    .then(function (result) {
        userCampus = result.customFields;
        return userCampus
    .then(function (userCampus) {
        window.dataLayer.push(userCampus)
        window.dataLayer.push({'event': 'campusEvent'});
    .catch(function (error) {
        console.log('error', error);
var APIURL = window.origin.concat('/api/v1/me')
getUserCampus(APIURL);
</script>
That’s it! (Feel free to yell at me if you find problems with this approach. Always happy to learn.)
