I tried to upgrade Docker-Installation from Rocket 4.0.6 (which runs fine) to next 4.1.x oder latest 4.3.1.
Rocket does not start and log shows errors:
- Version of Rocket.Chat Server: 4.0.6
- Operating System: Synology NAS
- Deployment Method: Docker →
- DB Replicaset Oplog:
- NodeJS Version:
- MongoDB Version: 4.4.11
- Proxy: haproxy–>
- Firewalls involved: no
LocalStore: store created at
[connection] Error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
Error occurred: Error [ERR_STREAM_DESTROYED] [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
at doWrite (_stream_writable.js:399:19)
at clearBuffer (_stream_writable.js:542:7)
at Socket.Writable.uncork (_stream_writable.js:338:7)
at JSStreamSocket.doWrite (internal/js_stream_socket.js:176:17)
at JSStream.onwrite (internal/js_stream_socket.js:33:57)
at JSStream.callbackTrampoline (internal/async_hooks.js:126:14)
at Socket.ondata (internal/js_stream_socket.js:77:22)
at Socket.emit (events.js:314:20)
at Socket.EventEmitter.emit (domain.js:483:12)
at addChunk (_stream_readable.js:297:12)
at readableAddChunk (_stream_readable.js:272:9)
at Socket.Readable.push (_stream_readable.js:213:10)
at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
at TCP.callbackTrampoline (internal/async_hooks.js:126:14) {
code: 'ERR_STREAM_DESTROYED',
source: 'socket'
meteor://💻app/app/app.js:196585
throw err;
source: 'socket'
Tried 1 times. Waiting 5 secs...
throw err;
Docker-File is this one:
version: '2'
services:
rocketchat:
#image: rocketchat/rocket.chat:4.3.1
image: rocketchat/rocket.chat:4.0.6
command: >
bash -c
"for i in `seq 1 30`; do
node main.js &&
s=$$? && break || s=$$?;
sleep 5;
done; (exit $$s)"
restart: unless-stopped
volumes:
- /volume1/docker/rocketchat/uploads:/app/uploads
- /volume1/docker/rocketchat/emoji:/app/emoji
- /volume1/docker/rocketchat/sounds:/app/sounds
- PORT=3000
- ROOT_URL=http://192.168.217.10:3000
# - MAIL_URL=smtp://smtp.email
# - HTTP_PROXY=http://proxy.domain.com
# - HTTPS_PROXY=http://proxy.domain.com
depends_on:
- mongo
ports:
- 3000:3000
labels:
mongo:
#image: mongo:4.4.11
image: mongo:4.4.11
volumes:
- /volume1/docker/mongodb/db:/data/db
- /volume1/docker/mongodb/dump:/dump
command: mongod --oplogSize 128 --replSet rs0
labels:
- "traefik.enable=false"
mongo-init-replica:
image: mongo:4.4.11
command: >
bash -c
rs.initiate({
_id: 'rs0',
sleep 5;
done; (exit $$s)"
depends_on:
- mongo
#hubot:
# image: rocketchat/hubot-rocketchat:latest
# restart: unless-stopped
# environment:
# - ROCKETCHAT_URL=rocketchat:3000
# - ROCKETCHAT_ROOM=GENERAL
# - ROCKETCHAT_USER=bot
# - ROCKETCHAT_PASSWORD=botpassword
# - BOT_NAME=bot
# - EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics
# depends_on:
# - rocketchat
# labels:
# - "traefik.enable=false"
# volumes:
# - /volume1/docker/rocketchat/hubot/scripts:/home/hubot/scripts
# this is used to expose the hubot port for notifications on the host on port 3001, e.g. for hubot-jenkins-notifier
# ports:
# - 3001:8080
#traefik:
# image: traefik:latest
# command: >
# traefik
# --docker
# --acme=true
# --acme.domains='your.domain.tld'
# --acme.email='your@email.tld'
# --acme.entrypoint=https
# --acme.storagefile=acme.json
# --defaultentrypoints=http
# --defaultentrypoints=https
# --entryPoints='Name:http Address::80 Redirect.EntryPoint:https'
# --entryPoints='Name:https Address::443 TLS.Certificates:'
# ports:
# - 80:80
# - 443:443
# volumes:
# - /var/run/docker.sock:/var/run/docker.sock
