Error: ESOCKETTIMEDOUT at ClientRequest.<anonymous>
I am using a outgoing-webhook and actually the response takes more than 1 minute. Seems like the timeout is less than 1 minute. How can I solve this error?
node_modules/request/request.js:816:19)
at Object.onceWrapper (events.js:273:13)
at ClientRequest.emit (events.js:182:13)
at Socket.emitTimeout (_http_client.js:714:34)
at Socket.emit (events.js:182:13)
at Socket._onTimeout (net.js:447:8)
at ontimeout (timers.js:457:11)
at tryOnTimeout (timers.js:327:5)
at listOnTimeout (timers.js:301:5) code: ‘ESOCKETTIMEDOUT’, connect: false }
Let me see if I understand.
You are consuming an API and it’s taking too long to return, so the integration doesn’t work?
I am not sure you can change the webhook integration timeout right now. If that’s what you need, we can probably open up a feature request.
Hi there,
We can add the timeout in HTTP.call(). This can be added in app/integrations/server/lib/triggerHandler.js.
It worked for me. Thanks.
Oh, ok.
There’s always a way if you can edit the code :wink:
But it would be nice to have an option for that under the Advanced Settings for the integration.
