I ran the docker-comose file for migrating from mmap to wiredtiger, and everything seems to have migrated, but how do I now run the system without the migration portion? I don’t find updated compose info for a “new install” or an existing wiredtiger setup.
Additionally, my push notifications no longer work, and the system is quite slow. Clearing items as read isn’t working, and I’m having to manually reload a lot of times.
Version of Rocket.Chat Server: 4.0.1
Operating System: Ubuntu Server with Docker-CE and Docker-Compose
Deployment Method: Docker and Docker-Compose
DB Replicaset Oplog:
NodeJS Version: Whatever you set in Docker
MongoDB Version: 4.2
Proxy: NGinX
Firewalls involved: none
Follow the official rocketchat guide on migrating from mmap to wiredtiger.
Checked logs.
Looked for updated docker-compose to run with existing wiredtiger setup, but unable to locate one in Rocketchat official docs.
We are working on updating the docker-compose file.
We have now 2 PRs for that, and will merge one of those soon:
and
regarding the Push not working anymore, were you able to gather more logs about it?
Also, we have newer versions (latest is 4.1.0) can you teste on those and see if it gets fixed?
Sorry for the late reply. No I haven’t been able to gather logs. If you can tell me where to gather logs from, I’m happy to do so. I also notice, my RocketChat client and web UI don’t get updates when new messages are posted anymore either. Perhaps fixed in the updated version. The issue is I don’t know how to update without an updated compose file that will not specify mmapv1 since the migration to WiredTiger engine.
Hi, let me add to what @dudanogueira already stated.
Revert the changes you made for the migration step and change the command section under the mongo service to mongod --replSet rs0 (what Duda has over there works as well).
Seems like this issue is surfacing after mmap to wiredtiger migration. Known internally and hopefully we’ll provide a solution soon.
