Docker Container for Raspberry Pi 4
Has anyone found a Docker Container that is compatible with the Raspberry Pi 4? Or a Raspberry Pi 4 Docker Swarm.
Totally. Both! Please see this up-to-date repository for some ideas …
When I ran the docker file, I got the dreaded:
standard_init_linux.go:211: exec user process caused "exec format error"
I’m not sure what image it pulled to cause that error.
Here is the full output:
pi@docker-master:~/dockerfiles $ docker build -t rocketchat rc
Sending build context to Docker daemon 4.096kB
Step 1/24 : FROM arm64v8/node:8.15-stretch as builder
8.15-stretch: Pulling from arm64v8/node
5385e634d2a1: Pull complete
6696bae2f570: Pull complete
6dca82770cb3: Pull complete
d95e88827e80: Pull complete
6f7b6531f1d8: Pull complete
8ca96e14ebcf: Pull complete
fb4b26362d76: Pull complete
dd914fbcdb57: Pull complete
Digest: sha256:47176f64002fb119f51372ef928008a8bddc83d0cd6627275e0295eb84b76444
Status: Downloaded newer image for arm64v8/node:8.15-stretch
---> ebc0fd89a035
Step 2/24 : MAINTAINER buildmaster@rocket.chat
---> Running in d23f2208dafe
Removing intermediate container d23f2208dafe
---> 230c70d40bc7
Step 3/24 : RUN groupadd -r rocketchat && useradd -r -g rocketchat rocketchat && mkdir -p /app/uploads && chown rocketchat.rocketchat /app/uploads && echo "disable-ipv6" >> ~/.gnupg/dirmngr.conf
---> Running in 00ee15edfa60
The command '/bin/sh -c groupadd -r rocketchat && useradd -r -g rocketchat rocketchat && mkdir -p /app/uploads && chown rocketchat.rocketchat /app/uploads && echo "disable-ipv6" >> ~/.gnupg/dirmngr.conf' returned a non-zero code: 1
Are you building using the OS from --> the arm64 18.04lts for pi4 image on this page?
