hello can you guys help me.
I want to make a color in the flatlist, so on row 1 (0001) it is blue, then on row 2 check “is the item in row one the same as row 2?”, if it is the same then the color is also the same…
- then when you go to row 3, you have an item that is different from item 2, so the color is also different.
- then when you go to row 4, you have an item that is different from item 3, so the color is also different.
-etc.
thanks-
