Hello, I have an issue with cas connection.
I must use CAS connection because we have 2 domains, and rocketchat can only use 1 ldap domain at same time
Thank you
“no matching login attempt found” popup message when attempting to connect with CAS.
URL are correctly configured: https://url/cas & https://url/cas/login
Cas connection works with other appliance like moodle
- Version of Rocket.Chat Server: 2.4.7
- Operating System: Ubuntu 18.04
- Deployment Method: Manual
- DB Replicaset Oplog:
- NodeJS Version: v8.11.4
- MongoDB Version: 4.0.16
- Proxy: nginx
- Firewalls involved: fortinet
This is the only log i have when i try to connect:
I20200219-14:39:06.420(1) server.js:204 CAS ➔ error error when trying to validate: unable to verify the first certificate
Popup message: no matching login attempt found
