I have a Rokcetchat instance running and i want to use AWS Cognito as a OAuth Provider.
It should work but there is one problem as shown in the logs below.
- Version of Rocket.Chat Server: 3.14.1
- Operating System: Ubuntu 20.04, microk8s-Cluster
- Deployment Method: docker/kubernetes
- DB Replicaset Oplog: activated
- NodeJS Version: v12.22.1
- MongoDB Version: 4.0.24
- Proxy: traefik
- Firewalls involved: no
{"line":"405","file":"oauth_server.js","message":"Error in OAuth Server: Failed to fetch identity from amazon at https://cxde-sso.auth.eu-west-1.amazoncognito.com/oauth2/userInfo. failed [401] {\"error\":\"invalid_token\",\"error_description\":\"Access token does not contain openid scope\"}","time":{"$date":1621586869805},"level":"warn"}
Exception while invoking method login Error: Failed to fetch identity from amazon at https://cxde-sso.auth.eu-west-1.amazoncognito.com/oauth2/userInfo. failed [401] {"error":"invalid_token","error_description":"Access token does not contain openid scope"}
