Have successfully installed Rocket.Chat on an Amazon Linux 2 LTS instance, and can run the app directly via:
export PORT=3000
export ROOT_URL=http://my-public-ip:3000/
export MONGO_URL=mongodb://localhost:27017/rocketchat
node /opt/Rocket.Chat/main.js
However, getting Rocket.Chat to run via systemd is not working. My /lib/systemd/system/rocketchat.service file looks like:
[Unit]
After=network.target remote-fs.target nss-lookup.target nginx.target mongod.target
[Service]
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=rocketchat
User=root
Environment=MONGO_URL=mongodb://localhost:27017/rocketchat
Environment=ROOT_URL=http://my-public-ip:3000/
Environment=PORT=3000
ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js
[Install]
WantedBy=multi-user.target
What I get with systemctl start rocketchat.service:
[root@ip-172-30-4-231 system]# systemctl status rocketchat.service -l
Loaded: loaded (/usr/lib/systemd/system/rocketchat.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2018-03-17 01:07:09 UTC; 13min ago
Process: 4148 ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js (code=exited, status=8)
Main PID: 4148 (code=exited, status=8)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Function.Module._load (module.js:312:12)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Module.require (module.js:364:17)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at require (module.js:380:17)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Object. (/opt/Rocket.Chat/main.js:4:1)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Module._compile (module.js:456:26)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Object.Module._extensions…js (module.js:474:10)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal rocketchat[4148]: at Module.load (module.js:356:32)
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal systemd[1]: rocketchat.service: main process exited, code=exited, status=8/n/a
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal systemd[1]: Unit rocketchat.service entered failed state.
Mar 17 01:07:09 ip-172-30-4-231.ec2.internal systemd[1]: rocketchat.service failed.
What am I missing?
