502 after restart
We have a rocket server, running on ubuntu 22.04, docker image in AWS. We have three rocket chat servers like this, and the issue I am about to describe only happens to this one.
Anytime this server crashes (every few months or less thankfully), or we have to update the version and restart it, it comes back with a 502. Everything is the same as it was before.
The only fix I have found, is to make an image of one of the working rocket chat servers. Change the domain name in the nginx and docker configs, and then mongorestore a dump from the broken server.
This will then work, as long as we don’t shut it down or reboot, until the next time.
  • Version of Rocket.Chat Server: 6.6.5
  • Operating System: ubuntu 22.04
  • Deployment Method: docker
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
compose.yml
volumes:
services:
  rocketchat:
    image: registry.rocket.chat/rocketchat/rocket.chat:${RELEASE:-latest}
    restart: always
    labels:
      traefik.enable: "true"
      traefik.http.routers.rocketchat.rule: Host(`${DOMAIN}`)
      traefik.http.routers.rocketchat.tls: "true"
      traefik.http.routers.rocketchat.entrypoints: https
      traefik.http.routers.rocketchat.tls.certresolver: le
      MONGO_URL: "${MONGO_URL:-\
        mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
        ${MONGODB_DATABASE:-rocketchat}?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      MONGO_OPLOG_URL: "${MONGO_OPLOG_URL:\
        -mongodb://${MONGODB_ADVERTISED_HOSTNAME:-mongodb}:${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}/\
        local?replicaSet=${MONGODB_REPLICA_SET_NAME:-rs0}}"
      ROOT_URL: ${ROOT_URL:-http://localhost:${HOST_PORT:-3000}}
      PORT: ${PORT:-3000}
      DEPLOY_METHOD: docker
      DEPLOY_PLATFORM: ${DEPLOY_PLATFORM}
    depends_on:
      - mongodb
    expose:
      - ${PORT:-3000}
    ports:
      - "${BIND_IP:-0.0.0.0}:${HOST_PORT:-3000}:${PORT:-3000}"
  mongodb:
    image: docker.io/bitnami/mongodb:${MONGODB_VERSION:-5.0}
    restart: always
    volumes:
      - mongodb_data:/bitnami/mongodb
      MONGODB_INITIAL_PRIMARY_HOST: ${MONGODB_INITIAL_PRIMARY_HOST:-mongodb}
      MONGODB_INITIAL_PRIMARY_PORT_NUMBER: ${MONGODB_INITIAL_PRIMARY_PORT_NUMBER:-27017}
      MONGODB_ADVERTISED_HOSTNAME: ${MONGODB_ADVERTISED_HOSTNAME:-mongodb}
       ALLOW_EMPTY_PASSWORD: ${ALLOW_EMPTY_PASSWORD:-yes}
nginx config
server {
     listen 443 ssl;
     server_name rocket.allinlearning.com;
     ssl_certificate /etc/letsencrypt/live/rocket.allinlearning.com/fullchain.pem;
     ssl_certificate_key /etc/letsencrypt/live/rocket.allinlearning.com/privkey.pem;
     ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
     ssl_prefer_server_ciphers on;
     ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
     root /usr/share/nginx/html;
     index index.html index.htm;
     # Make site accessible from http://localhost/
     server_name localhost;
     location / {
         proxy_pass http://localhost:3000/;
         proxy_http_version 1.1;
         proxy_set_header X-Forwarded-Proto http;
         proxy_redirect off;
 server {
     listen 80;
     return 301 https://$host$request_uri;
