Update Kernel and Node?
#1
Hello Guys,
i updated to RC 070.4 running at CentOS7.
First i got Problems with 1to1 Chat and the E2E Encryption. Like when i enabled the E2E the other member of the chat couldnt see the message and couldnt write back.
After the weekend (nothing changed) the issue was gone …
But in saw in the Info from RC that there is a difference in the runtime enviroment and build enviroment:
Kernel and Node Versions are different
Kernel: 3.10.0 xxxx --> 4.4.0xxxx
Node: 8.9.3 —> 8.11.3
Are that the recommend Versions of Kernel and Node?
Should i update them? Do i have to?
And do it have to be the exact Versions or can i get newer ones?
Thanks for help
