Description:
We run Rocket.Chat as a Docker Compose stack, using the official compose files, which reference registry.rocket.chat/rocketchat/rocket.chat as the default registry.
registry.rocket.chat/rocketchat/rocket.chat:8.9.0contains Node.js v24.15.0, which is affected by Node2Shell (CVE-2026-111497).rocketchat/rocket.chat:8.9.0on Docker Hub contains Node.js v24.22.1, which includes the fix.- The two images with the same tag are not identical.
- When we use the Docker Hub image in our existing compose stack, Rocket.Chat cannot find its database and does not start.
docker image inspect registry.rocket.chat/rocketchat/rocket.chat:8.9.0 --format '{{.RepoDigests}} {{.Created}}'
[registry.rocket.chat/rocketchat/rocket.chat@sha256:295f7b2c38fc3542024dc404f887eb2e13276b66e5854d31d86bcd069f6ce6dc] 2026-10-05T18:05:45.433716326Z
docker run registry.rocket.chat/rocketchat/rocket.chat:8.9.0 node -v
v24.15.0
docker image inspect rocket.chat:8.9.0 --format '{{.RepoDigests}} {{.Created}}'
[rocket.chat@sha256:ea4430c6122371222ba90ba322c2111b5271927e67ecc438dcb686cc3899c62a] 2026-10-28T02:37:22.906164704Z
docker run rocket.chat:8.9.0 node -v
v24.22.1
Shouldn’t the image be the same in both?
Questions:
- Can someone explain why does the 8.9.0 image in RC own registry contain an older Node.js version than the Docker Hub image?
- Will the registry.rocket.chat image be rebuilt with the fixed Node.js version, and when?
Thank you.
- Version of Rocket.Chat Server: 8.9.0
- Operating System: Ubuntu 24.04.5 LTS
- Deployment Method: Docker Compose
- DB Replicaset Oplog: 1
- NodeJS Version:
- MongoDB Version: 8.0
- Proxy: 0
- Firewalls involved: 1
