Rocket.Chat Documentation - Testing
#1
Run meteor with the command below:
To run the tests, the server must be started with the environment variable TEST_MODE=true. This will set all animations’ duration to 0 and create an extra admin user with the login values:
This is a companion discussion topic for the original entry at https://rocket.chat/docs/developer-guides/testing/
