Rocket.Chat Documentation - Save Room Settings
#1
Save Room Settings
Requirements
Logged In Permission Setting Yes edit-room none
Payload
  1. String - the id of the room to leave
  2. String - the room setting to save
  3. Any - the value of the setting to save, this value type depends on what the setting accepts
Available Settings
Setting Accepted Values roomName String roomTopic String roomDescription String roomType c or p readOnly Boolean systemMessages Boolean default Boolean joinCode String
Example Call
    "msg": "method",
    "method": "saveRoomSettings",
    "id": "16",
    "params": [
        "roomId",
        "setting",
        "value"
Example Response
    "msg": "result",
    "id": "16",
    "result": {
        "result": true,
        "rid": "roomId"
See Also
This is a companion discussion topic for the original entry at https://rocket.chat/docs/developer-guides/realtime-api/method-calls/save-room-settings/
