Rocket.Chat Documentation - SAML
#1
This is the unique name for your application as a Service Provider (SP) for SAML. Whatever you enter here will produce a metadata XML file you will need in order to populate the metadata your IdP (Identity Provider) requires. For example, if you put ‘my-app’, then your metadata will be at:
This is a companion discussion topic for the original entry at https://rocket.chat/docs/administrator-guides/authentication/saml/
