Rocket.Chat Documentation - Managing Settings Using Environment Variables
#1
You can set any settings value via an environment variable when starting your server. You will only have to know the setting id and what type of setting it is (boolean, string, integer, etc…).
This is a companion discussion topic for the original entry at https://rocket.chat/docs/administrator-guides/settings-via-env-vars/
