Rocket.Chat Documentation - Get Public Settings
#1
This method is used to retrieve the public settings, such as Site Name. It accepts a timestamp as the first and only parameter which causes the results to be an object that contains the updated and removed settings after the provided time. If you want to retrieve all of the public settings, just omit the parameter.
This is a companion discussion topic for the original entry at https://rocket.chat/docs/developer-guides/realtime-api/method-calls/get-public-settings/
