Nginx crashes with 'host not found in upstream "backend"' after following reverse proxy instructions
I have been trying to set up an Nginx reverse proxy for SSL for a while now, but I keep getting problems. This is the most recent one. Following the setup instructions in the official documentation leads me to a dead end where I just cannot get it running, and I have no idea where I’ve gone wrong. Our server is behind Cloudflare, which I’ve heard can greatly complicate this.
I have changed the site’s name to mysite.example, as it’s run on my friend’s server, who doesn’t want me spreading the domain until the chat is fully set up. Our Cloudflare SSL settings are on ‘flexible’, and I was also wondering whether or not I should just turn them off completely.
  • Version of Rocket.Chat Server: 3.12.1
  • Operating System: Ubuntu Xenial
  • Deployment Method: Tar
  • NodeJS Version: 12.18.4
  • MongoDB Version: 4.0.23
  • Proxy: Nginx
  • Firewalls involved: Cloudflare, UFW
Upstreams
upstream backend {
server 127.0.0.1:2052;
HTTPS Server
server {
listen 443;
server_name mysite.example www.mysite.example;
# You can increase the limit if your need to.
client_max_body_size 200M;
ssl on;
ssl_certificate /etc/letsencrypt/live/mysite.example/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mysite.example/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # don’t use SSLv3 ref: POODLE
location / {
    proxy_pass http://backend;
    proxy_http_version 1.1;
    proxy_redirect off;
service file
[Unit]
After=network.target remote-fs.target nss-lookup.target nginx.service mongod.service
[Service]
ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=rocketchat
User=rocketchat
Environment=MONGO_URL=mongodb://localhost:27017/rocketchat?replicaSet=rs01 MONGO_OPLOG_URL=mongodb://localhost:27017/local?replicaSet=rs01 ROOT_URL=https://mysite.example PORT=2052
[Install]
WantedBy=multi-user.target
