When you add the Livechat script (omnichannel) to a web page when the html loads it then removes anything from the main pages style attribute on body!
This needs fixing. I assume a JS selector is being used without being specific to the dom element it should relate to which is in the iframe.
Anyone else have this issue?
Not seen this reported anywhere else.
Can you confirm which version you are using?
Please test on latest 3.15.x and let us know.
I am running 3.15.0.
If i have “body id=“page-top” style=“background-color: grey;” then it just becomes “body id=“page-top” style=””
I keep my version up to date with whats released on snaps and it has been like this every update so far.
I can’t see anything in the widget that would override your body styling?
I have the widget on a few sites and have never seen it myself.
Since I was sure the JS for the widget was at fault, I decided to debug this myself. I’m not sure how you state there’s nothing there that would override the body style.
See below snippet from rocketchat-livechat.min.js, the fault is in bold. The ‘s’ variable is not set at that point hence the inline style becomes blank on script execution. I have not analysed the whole JS script but I prooved this by replacing ‘s’ with “background-color: red;” and it sets my background to red overriding whatever was there before. This is from a quick 5 mins look so appologies if I have missed something and I hope this helps you.
p && t ? (d = document.documentElement.scrollTop, s = document.body.style.cssText, document.body.style.cssText += “overflow: hidden; height: 100%; width: 100%;”) : (document.body.style.cssText = s, p && (document.documentElement.scrollTop = d)), t ? (r.style.left = p ? “0” : “auto”, r.style.width = p ? “100%” : “”.concat(397, “px”), r.style.height = p ? “100%” : “”.concat(627, “px”)) : (r.style.left = “auto”, r.style.width = “”.concat(86, “px”), r.style.height = “”.concat(86, “px”))
Can you confirm you added the JS at the correct place JUST before </body>
Yes it is the last script entered on the page just before the closing body.
I haven’t studied that rocketchat-livechat.min.js in detail however document.body.style.cssText would affect the main page regardless wouldn’t it? So based on that the if statement using document.body.style.cssText = s when ‘s’ isn’t set will never be the correct action unless I am missing something.
Also I have tested with the following HTML. This has exactly the same problem, inline style attribute is set to “” rather than being left as “background-color: red;”. Again I dont see how any settings will affect this, the JS function being used with a variable that is null is the cause.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0, shrink-to-fit=no">
<title>Test</title>
</head>
<body id="page-top" style="background-color: red;">
<h1>Test 1</h1>
<!-- Start of Rocket.Chat Livechat Script -->
<script type="text/javascript">
(function(w, d, s, u) {
w.RocketChat = function(c) { w.RocketChat._.push(c) }; w.RocketChat._ = []; w.RocketChat.url = u;
var h = d.getElementsByTagName(s)[0], j = d.createElement(s);
j.async = true; j.src = 'https://<domain>/livechat/rocketchat-livechat.min.js?_=201903270000';
h.parentNode.insertBefore(j, h);
})(window, document, 'script', 'https://<domain>/livechat');
</script>
</body>
</html>
Hmmm. I haven’t ever seen this happen.
I’ve asked someone who might know. Please be patient while I try and find and answer.
No problem, thanks for looking into it.
I also had a customer who had a rocket chat server and wanted the widget on their site but when they added it the same thing happened. I worked around it but its not ideal.
I’ll wait to hear back.
Yes very odd as I have it on a couple of sites with no issue!!
Someone will let me know in due course and I’ll report back.
Out of curiosity is the rocket chat server a self hosted one? Also do you have a style attribute set on the body tag or just styles that apply to body?
Ahhh - I can see it now. Just tried in a simple site.
Hmmm. Interesting. I need to speak to a dev about that.
Can you leave it with me - we may need a bug, but let me check first.
Yes same thing, what is the next step?
See if I can get the Product Team to get it fixed PDQ!
I have already raised it. It will probably miss the current sprint unless it has already been picked up.
I will check if it is already in hand or not - probably tomorrow
Thanks for your attention to the problem, John!
No worries. I have raised the bug internally.
I can’t say when it will get fixed but it will get done.
Thanks John, appreciate the time and effort.
