The current code logs into Rocket Chat and goes to RoomsListView.
But I wanted DirectoryView to be main so I modified the code to Can’t get channel information properly from DirectoryView.
Returns an error.
{data": {“message”: “You must be logged in to do this.”, “status”: “error”}, “status”: 401}
However, if you click User and Channels in the selection tab, the data is loaded normally.
I hope it doesn’t give a 401 error on first load. How should I handle it?
const ChatsStack = createStackNavigator({
DirectoryView: {
getScreen: () => require('../../views/DirectoryView').default
RoomsListView: {
getScreen: () => require('../../views/RoomsListView').default
RoomActionsView: {
getScreen: () => require('../../views/RoomActionsView').default
RoomInfoView: {
getScreen: () => require('../../views/RoomInfoView').default
RoomInfoEditView: {
getScreen: () => require('../../views/RoomInfoEditView').default
RoomMembersView: {
getScreen: () => require('../../views/RoomMembersView').default
SearchMessagesView: {
getScreen: () => require('../../views/SearchMessagesView').default
SelectedUsersView: {
getScreen: () => require('../../views/SelectedUsersView').default
MessagesView: {
getScreen: () => require('../../views/MessagesView').default
AutoTranslateView: {
getScreen: () => require('../../views/AutoTranslateView').default
NotificationPrefView: {
getScreen: () => require('../../views/NotificationPreferencesView').default
...RoomRoutes
defaultNavigationOptions: defaultHeader,
cardStyle
